one hot motha F**ker
bmxruler4130
Car: a 91 se
lately my 240 likes to overheat. it only happens when im on the high way or when i rev. the car for a little while (at about 3-4 grand). the coolent is full, but i might be old. and the radator looks fine. all the hoses are good too. mabe a water pump? possably a head gasket? but it runs fine.. just a little rough but not out of the ordinary.
yellow_jacket
Car: 95 240sx
Sounds more like a plugged radiator or bad thermostat. Head gaskets usually overheat almost randomly. Water pumps usually make a lot of noise when they start to go bad. A radiator shop will be able to flow check the radiator for you for about $45 and if it is bad that money goes towards a new metal one that they sell.
Silvia007
Car: 93 Nissan 240SX SE Fastback
Here's what I think is going on, there's a air pocket circulating in your cooling system. First off, take off ur radiator cap. Keep your motor rev'ed to about 3k and just wait, it'll over heat and when it does, ur thermostat will open all the way allowing lots of water to run out... becareful as lots and lots of coolant might blow out from the opening where the cap goes to... and once that happens and calms down, fill it up with coolant and ur set. If it still overheats, repeat the process. I work at Jiffy Lube and we have lots of cases like that. Hope that helps.
yellow_jacket
Car: 95 240sx
That is precisely why Nissan put a bleeder on their cooling system.
bmxruler4130
Car: a 91 se
where is the bleeder.. and will useing the bleeder get rid of the air bubble?
Silvia007
bleeder is too small to rid big air bubbles. it'll take some time but bleeder to me is too slow. TO find the bleeder, follow ur top radiator hose all the way from the radiator to the block, right where the hose connects to the aluminum of the block, the bleeder should be a zerk or fitting with a 10 mm bolt.
signal180sx
Car: 2004 IS300 Supercharged
does the bleeder leak out fluid as well?
bmxruler4130
Car: a 91 se
cars all fixed... turns out it was just the belt to the water pump slipping
