One Full Day
reggiegsd
Car: '94 Q, '73 240Z
Me and a buddy, who will do anything for free beer, put in a full day on the 94Q. New plugs (previous post), new Tokicos all around, rear sway bar, fresh bushings, oil change, fuel filter, flushed the radiator, cleaned the TB and intake, and mounted the new wheels and tires. A well invested 10 hours.
The old girl seems quite happy with her new shoes and is looking good.
Next oil change will include new brakes and nylon bushings for the sway bars.
Obviously, I've decided not to sell her.
reggiegsd
The tires I put on are 245/45-16s. They are just a little too short, about %6 or so. The car feels like I just changed the rear to about 4.00 or 4.01.
This deffinitly woke up the off idle performance of this car!
PalmerWMD
Car: 2004 350Z
That's great!
Must feel good to have everything in perfect shape and new wheels too!
I feel some members ride pictures coming in...
Fred...:)
reggiegsd
Palmerwmd, with the brake mods you mention did you also use the 300ZX calipers? If so, any pointers being that is my next project.
BradM
Car: My Family, Aviation, Hockey
"Me and a buddy, who will do anything for free beer,......." :beerchug
I think I can fit a keg in the back seat. Probably cans or bottles only in the trunk. Time for a road trip.:D
Brad
reggiegsd
Wow!
After driving the '94Q with the shorter tires (245/45-16s) for a few days I am impressed with the change in the car's character. The low end improvement is obvious. It is probably comparable to the earlier Qs with the shorter first gear ratio.
Yes, I understand the engine is reving higher and the speedo is off. I also understand better push when I feel it.
The new Tokikos all around plus the rear sway bar and fresh bushings tightened things up appreciably. Even Wifey Dear noticed.
If you are willing to live with the trade-offs, consider a little shorter tire. Its alot cheaper than a new rear end.
wamQ45
Now if we could just convince women to do anything for free beer...
Q45tech
840-847 revs per mile vs 800 [215/65/15] is 5% roughly the same as the downward gear changes in 94-96Q.
This size appears to only come in : 94 or less [1477-1300 pound load rating] lower than the oem minimum 95 index of 1521 pounds?
Rolling diameter is critical as a smaller tire has less time away from the road to COOL at the same speed so it runs hotter thus has less life and faster wear [all things being equal].
I am always promoting using bigger tires [larger diameter stronger] with a higher than the factory minimum load rating to enhance performance, safety, and life.....having a little extra reserve is always good as you never know how close the factory cut it.
255/50/16 is a great size and usually has a 100-160 pound greater load capacity than the oem tires with the same diameter.
reggiegsd
Yes, you are right about the 94 load rating. (Yoko AVS Intermediates)
Judging from the way these tires stick and howl, they will not last long. Next set will be 255/50-16s. In the mean time, I'm grinnin' like a monkey.
I have used several sets of Yoko A008s on street Zcars and managed to get about 8K out of a set. I was rather proud of myself.
greg_atlanta
Car: 2008 G35 Journey Sedan, silver/black (no sunroof), 1992 Q45 (in a past life)
reggiegsd wrote:(Yoko AVS Intermediates)
Judging from the way these tires stick and howl, they will not last long. In the mean time, I'm grinnin' like a monkey.
I've been grinning like a monkey for 2 years and have been trying to get other people to buy them.... but everybody chickens out.
:chicken :chicken :chicken
Glad to see you like them. I'm about to order another set for next summer, just gotta find the closet space to keep them inside so they don't get hard outside in the cold!!
:rockon :rockon :rockon
My 235/60/15 did get pretty hard sitting in the closet on my back porch.... but they've been fine all summer. Still very quiet and sticky, just not as sticky as before. But getting a little too slick for rain... so back to AVS dB tires soon!
Aus94Q45
Car: 1994 Q45
That is one heck of a day's work. I'll supply any brand of beer you want and a bottle of Patrone to chase it down for all that! Really, how many hours?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I'm coming for the Patron, preferably Añejo !
reggiegsd
If you want the Yoko AVS Intermediates you had better hurry. They are being replaced by the ES100. I have no experience with that tire.
reggiegsd
Quote »That is one heck of a day's work. I'll supply any brand of beer you want and a bottle of Patrone to chase it down for all that! Really, how many hours?[/quote]
This wasn't very hard. I owned a 300ZXTT for a couple of years and the plugs and the shocks are almost identical. The hardest part was installing the rear sway bar.
Alot of time (and beer) was consumed "bench racing".
Aus94Q45
Car: 1994 Q45
Anejo it is! Not much better than that!
greg_atlanta
reggiegsd wrote:If you want the Yoko AVS Intermediates you had better hurry. They are being replaced by the ES100. I have no experience with that tire.
And the ES100 doesn't come in a proper size for the Q stock wheel, closest match is 215/60/15, 94 load rating... which would probably work OK, but wear out faster.
