Once again ssauto problems
CaEric
Car: 91 Sr Pwred Coupe
SO i got my manifold and the ports are not even the same dam size....Also anyone who has ever read that 300zx exhaust manifold gaskets work.....there to dam small also !!!!!!
themadscientist
Why do people continue to buy this ****? Did you not read all the problems others have had? If you did why would you waste the money?
float_6969
ALL tubular manifolds have larger diameter ports than the head. It helps to fight reversion. They're like that on purpose. And which gaskets are you talking about? If you mean the head-->manifold gaskets, then no, the Z ones won't work. You're supposed to use the Pulsar gaskets. If you mean the mani to turbo gasket, then yes, the Z one does work. If you mean the turbo outlet gasket, then no, the Z doesn't work. There isn't a US equivalent in Nissan, and you'd be best off just ordering one from one of our supporters like Heavy Throttle.
CaEric
well what other choice do i have for manifold? no ima talk bout the manifold to head
float_6969
You don't have too many choices unless you want to have one built, or wait for 3 months to get one from Rare Trick.
And just to reiderate, if you need the gaskets that go from the head to the exhaust mani, then you need to get plain ole flepro gaskets for an 88 Nissan Pulsar NX SE w/the CA18DE.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
Copper seal is your friend when you cant find gaskets!
also im doing log manifolds for cheap right now since im broke. my tubular prices wont waiver much due to time involved in building them from scratch.
i am thinking about making some SS turbo to downpipe gaskets for the t25/t28/gt28RS/2871. i made them for t3/t4s and they sold like hot cakes.
BACARDI_DWB
did you get the top mount or the bottom mount SSautocrap mani?
CaEric
bottom mount mani.....it biolts up fine even uesd the tube to connect the exhaust with....jsut the ports were screwey
UNITEDMOTORSPORTS
Car: s13 s14 cressida
i got one from them for top mount then changed the flage to acept t25 flange for the s15 turbo i got.. the manifold is fine especially after porting the head and i added some braces for manifold to block and braced the manifold some more its all fine and dandy.. your could buy one from boss auto produce in japan for 1800 usd.
float_6969
What do you mean the ports were screwy? They didn't like up or they were too big? Like I said before, they're SUPPOSED to be bigger than the exhaust ports on the head. It helps to fight reversion.
