On throttle Smoke
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
My KAE-T smokes pretty badly when I am in Boost. Would this indicate broken ringlands or bad turbo seals. I can't get an accurate compression test do to low battery voltage until my new alternator gets here. There also is a little shaft play on the turbo but I don't know how much is acceptable there? I am running a restrictor in the feed line.
Comments?
fiznat
Car: Grown up :(
Can you describe the smoke? Is it white and sweet smelling, blueish tinted, or a dark black color?
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
I would say mostly white maybe a little blueish, Its hard to tell because it only happens when I am in full boost and I have to look at it in the RV mirror.
Iamjohnhayes
Car: 89 Single Cam Hatch
drive by a friend while in full boost and ask him to tell you the color. and how much shaft play do you have?
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
It's oil burning i know that for sure. It seems to get better when the car is nice and warm also.
Mishka
Hey, I have the same problem. Compression test shows 180 psi in all 4 cylinders. The turbo is new. But the car still smokes a little at WOT. I tend to think it's PCV system. I think that if I'll plug the hose going from oil separator to intake manifold or put it through oil catch tank the smoking should stop.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
I have a SOHC and the hose for the PCV (if it is the one that comes off of the valve cover) I routed towards the back of the engine bay and out the bottom. But it smoked before that anyways
Mishka
The one on the valve cover is inlet, the outlet that "sends" crank-case gases (with oil in my case) in the intake manifold is on the left side of the block on KA24DE.
