Did you leave the parking brake on? I would have to look at this but on most of my other cars the parking brake is a little drum brake on the rear wheels of my disk brake cars or the actualy drum brake on my others (except my 53 and 55 Plymouths which were a band on the driveshafts, didn't work so well). If the parking brake was left on for long periods (again may not apply to the G) they sometimes would stick to the drums. Basically I have always been able to free them by putting in neutral and rocking the car by hand, I don't suggest using the engine for this.smockers83 wrote:This evening/night I made the trip to see my G and bring it out of hibernation. This is the earliest I've brought it out but it's been too nice to not get it. Right now I'm cleaning my JWT filter.
Last time I saw it back in February, I started it up and after awhile I wanted to back it up a little so all the exhaust wasn't in the garage. Went to do that, put it in R and it wouldn't move. It was very cold out for a couple of weeks (below 0 and single digits) and this was the first time it had been ran since December 24. Could that have been the brakes being frozen or something?
I haven't started it up yet tonight but once I get the JWT back on in the morning, I'll be looking to start it and see if I can get it to move (it's been a lot warmer, 40s and 50s). I'm a little worried if it'll move or not, I think it will, but if it doesn't, what could be the issue?
You should have gotten a sticksmockers83 wrote:No, I didn't have the P brake on and haven't had it engaged because I know of the freezing up of the brake line. I let it run for about 5 minutes probably before trying to move it. It engaged in R and it felt like it wanted to move but something was stopping it, but I didn't try too hard, didn't want to push it.
I'll let it run a little longer this time.
Thanks guys.
It could be one or more stuck calipers?smockers83 wrote:I think I've solved my own problem. I did wash the car right before putting it in the garage to get all of the salt off. Could have rusted the rotors to the pads. All I can find about breaking them free is to just give it gas. Anything else I could do? I've been trying to break it free with some gas. Should I just keep doing that, give it more gas?
The rotor and the pads should not have rusted together if they were not in contact with each other when parked.smockers83 wrote:I think I've solved my own problem. I did wash the car right before putting it in the garage to get all of the salt off. Could have rusted the rotors to the pads. All I can find about breaking them free is to just give it gas. Anything else I could do? I've been trying to break it free with some gas. Should I just keep doing that, give it more gas?
