On the fence about flywheels
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
Dammitboy
Car: 92' Nissan 240
For my VH swap, can't decide on using the stock TT flywheel, or going with a 12 ouund one. I'll be using a OEM equilivant clutch, but is it possible to machine down a stock flywheel to shed a few pounds?
Thanks!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Ive never driven a VH/light flywheel but from what I understand the lighter flywheels make it a little harder to drive in a daily/city commute sort of thing..
Also, consider on the 4's and 6's, a flywheel and crank pulley are a much larger percentage of the total rotating mass... Not so much with a V8. The point is, a lighter crank pulley is known not to have any noticeable change, and I doubt that a flywheel would be that much different...
in other words, if you have a stock TT clutch and flywheel, I would just run that and worry about something new when it comes time to change it!
Carl H
i rocked out a 12lb flywheel on my vh car...throttle response was beyond silly.
kaje36
I ran a 10.5 lb flywheel on a KA24DE (inline 2.4l 4 cyl) and I couldn't see any drive-ability difference. I would Imagine if I put a light flywheel in my tow vehicle.. and needed to do some small, fine movements with a full load, I might have an issue, (or have to slip the clutch a lot more)
kingkilburn
Car: '93 240SX
Don't you need a reasonably heavy fly wheel to help even out the odd firing order?
s13loverdrift1
Car: Nissan 450sx (VH45DE swao)
I have a 10.5 pound one from z1. The response I will say sounds crazy (have no tach installed yet) The drivability difference I find to be very minimal inside the s13 I love the feel of the Z1 clutch and flywheel. I would just say go with the lightweight if you have the money to do so I don't know if you can get a stock flywheel that light. Ill post a vid once I install a tach.
Bart
I got a Fidanza alloy 300zxTT fly wheel, modified to suit a 350zx clutch. Got the clutch from South Bend, they can sell the whole assembly, 300zx flywheel with 350zx clutch. 350zx is softer on the foot with more clamping pressure.
s13loverdrift1
So is the 350zx a vq35 in a 300zx? just curious haha. just messing with you. Guessing you were tired.
Return to “VH45DE / VK45DE / VK56DE Forum”
