? on Setting Coilovers
ETTInnov04
Car: 1989 Nissan 240sx fastback
Have any of you set your preload and/or corner balanced your suspension after adding coilovers? I just purchased the Tein Flex kit and my uncle has all the scales and everything needed to set it all up. He said I needed to get him a baseline or somewhere to start from. I'm looking for neutral handling and the car will be used as Daily Driver/ AutoX. I'm a newbie at suspensions so any input welcomed. Thanks, Chris
Red coupe
Car: 92 Nissan 240sx Coupe
As advised to me when I was asking just put it on the scales and adjust preload to make the sides even and like a 51/49 front rear balance...Sounds like he knows how to do it, expecialy if he has the equipment...
