Sale is over! Thanks!
The E11v2 Is the big brother of the E8 boasting 12 Drivers, perfect for a full sequential 6 cylinder!
Again the haltech ecu trumps the Stock computer, the RB20 ecu only uses 2 ground drivers for injection!!
We have basemaps ready to go for all of these using stock injectors, or Get your complimentary first base map edited for larger injectors!
This kit is perfect for the Stock to fully upgraded ecu. Since the ECU is unlocked, you can easily modify it as you add modifications to your car.
PLUS! RPSports Personal tech support! We are an Authorized Haltech Dealer, well versed in the Haltech ECU.
In this Kit you get:Haltech E11v2 ECUPlug and Play Harness for the RB20DET, RB25DET, RB26DETT or VG30DETTData CableInstall CD with Manuals3 Bar Map sensorAir Temperature Sensor
E11v2 Specification Sheet
Add a boost controller! its only $88 bucks more!
Need a wideband? The haltech Wideband will synch with your ecu giving you Lambda datalogging over your runs. Synch it to closed loop, set your ecu and go! Only $200 more!
Get in touch! Pay via PayPal Verified!
AIM: RPSportJohnEmail: [email protected]: 562.489.5016
Modified by johngriff at 11:26 AM 1/15/2008
Modified by johngriff at 9:23 PM 2/10/2008
