95 altima Manual trans. Open differential. Bought the car with no fith gear. After running AC sometimes trans would get "HOT" and lock trans in 3rd and 4th gear. Id wiggle the shifter after turning the car off and finally could get the shifter freed up to go through 1-4th again Last time it did that i was hearing a clicking noise and something was definately flopping around inside and HARD.
I decided to pull the transmission. I got pissed after getting EVERYTHING off expect for 2 bolts on the transmission mount that were on the bottom transmission crossmember towards the rear of the car. So I tried to pull the case. Bolts were easy to get to and easy to gett off. well in my stooper I take what im assuming was the reverse gear spring to seperate the case from trans and some other undescrribed object falls out.(Pics) I need to now put these pieces back in because i found the problem. I will figure that out tom after i get the transmission out even if I have to just dropo the whole crossmember the get the bottom mounting bracket off, but looking at it through the axle hole looks like a solid metal rod not sure how long it is but looks about a half inch wide. that had to b rubbing against my axle making that horrible sound.
Questions
What can i do to get the bottom trans bracket off or do I need to drop the crossmember?
What is the part pictured how hard is it to get back in and can I hook the what im guessing is the reverse spring back up with out pulling the case completely off?
Any help is appreciated.
If someone is willing to help me along the way I will donate a nominal amount to this site and to them
The FSM section is great Mods THANKS!
Matt
