Ummmm 15 Just rebuild them. Your brakes shouldn't be leaking anything. Don't be a cheap ***, the rebuild kits are cheap and the rear calipers are too easy to find anyway. Just do it right.Dirtyl3um wrote:On a scale from 1-10, how stupid is this idea?
Not to mention your sister's life...!!!twistedsymphony wrote:brakes are a safety issue... if you want to put your life in the hands of jb weld, that's your decision, personally I'd find someone with a used set of calipers.
Encryptshun wrote:Wow, easy there, buffy.
Ok, maybe that was a little opportunistic of me.Encryptshun wrote:Look at the big brain on Claude.
:facepalm
not to be a buzz kill , but ive rebuilt 4 of them. all rears, 2 from an s13 chassi and 2 from an s14 chassi. and yes they all had those holes in them and hes not talking in the caliper hes talking about the piston inside the caliper. its rubber so it will deteriate, ever since ive rebuilt them we havent had a problem since. and its been two years now...with heavy driving/ track running. if the walls are scored best bet is to buy a used set, and depending on the condition of it might rebuild that one so all the sill's are good. or have them honed but if its badly scored new ones are a must. if you need pics of the holes i will send them to you just shoot me an email [email protected] but im not shooting down your experience or your service. just wanted to clerify what i said.after rereading it and rereading what i had posted it might not be for lub. might be a safty feature to keep you from driving. common sence tells you not to drive your car if you cant stop. (for myself)240sxbuffy wrote:WAKE UP YOU ARE TALKING ABOUT YOUR BRAKES !!!!!!!!!!!!!!!!!!!!! REPLACE THE CALIPERS BEFORE SOMEONE GETS HURT!!!!!!!!!!!!!!!!!!!!!!!!! THERE IS NO HOLE IN A CALIPER FOR LUBRCATION I AM A ASE CERTIFIED MASTER TECH I HAVE BEEN WORKING ON CARS FOR 27 YEARS THERE IS NO LUBE HOLE ON A CALIPER !!! IF THE DUST BOOT IS MISSING THEN THE CALIPER WILL SEIZE IF ITS LEAKING FLUID THEN ITS NOT WORKING AND DEATH IS A REAL POSSIBILITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You may be a ASE certified master tech but your spelling skills suck. No offense.240sxbuffy wrote:Maybe And yes you can rebuild caliepers and it is quite easy however if someone is even asking about trying to JB weld something they have no bussiness try to rebuild an item as important as a brakes!! plane and simple.
5buck to kill a loved one or 60 tobe sure she's all good.... ???YOU do the math lolDirtyl3um wrote: Ive called around and there gonna b 60 bucks a piece, and jb weld is like a 5 dollar container...
Input?
Not too many people do a swap on the rears though, as its a bit more involved...The rears don't do much braking anyways, and if I am not mistaken are on a different hydraulic circuit...twistedsymphony wrote:with the amount of people who swap in 300zx calipers good used calipers should be cheap money. Rebuild kits are cheap too... we're talking ~$30 (I would be shocked if used calipers would cost you much more than that).
