Omg, Walbro Boycotted For Life!!!!!!!! ***pics Inside***
skillzilla
So, I go to change out my fuel pump for the stock unit, and to my surprise, this is what I came up with when the cover came off:
And here are the chicnks of melted plastic that ended up in my gas tank:
The tank REEKED of melted plastic, and the pump body/level meter were coated with white dust from all the smoke. Im hellllla lucky I didnt burn my car to the ground with this POS. Needless to say, Walbro is going to get a Nastygram tonight.
PS, The stock pump works fine, so it wasnt the wiring.
frosted flakes
ouch that sux...ive had my walbro 255 running in my car for over 8 months now and no problems...
JonPowell
Car: Cars, Music, My family
Looks to me like it might have shorted out from being wired wrong, but I dont know for wure and dont want to insult you so I will keep my mouth shut.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
that really sucks. I have one on my car and haven't had any problems other than it running rich.
240driver39
we had a friend at school have a few week old walbro die out on him, made me consider other options as ive heard other instances.
S13ChucKAT
Car: asd
is it just me, or does
look like some kinda alien or something.. some kinda open mouth pissed off creature.. lol
skillzilla
OMG, it does, didnt even notice that.
I thought it looked like a doodoo ice cream cone :)
S13ChucKAT
Car: asd
dude, send it back to walbro, with a big ol pic of "WTF"
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
skillzilla wrote:So, I go to change out my fuel pump for the stock unit, and to my surprise, this is what I came up with when the cover came off:
It's just a flesh wound. A little sand paper work and it will be good to go.
skillzilla
:D
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
walbros arent reliable. they always die/lose pumping power rather quickly.
first time ive ever seen one fail in that manner.
use a bosch or an aeromotive next time.
Wulfgang
You should first try to find out what happened, if that is possible. That may not be Walbro's fault. It is possible that some trash got into the pump and jammed the gears.
As for the wiring... there is no way that was the issue -- unless you wired it up backwards (reverse polarity). There is no way to "short" the wiring to a pump. If you short it, the pump just sees 0 voltage.
Where did you purchase your Walbro?
skillzilla
I got the pump from a seller on ebay. All I can think of is that the fuel lines being switched caused the pump to overload by trying to push pressure into the FPR the wrong way. I would assume that the pump has a safety built in to prevent this type of thing from happening, but it may have been faulty. Im just glad to alive and sans 1st degree burns from being in the drivers seat as my car exploded :)
Wulfgang
I'm not sure that would be an issue either. Both ends of the fuel rail have identical regulators. They are mirror images, except that the one in the back has no vacuum hose connection to the manifold. If you were to hook up the fuel lines backwards, it seems to me like it would still pump, only you'd be running really rich at idle, so it might not crank. Shouldn't have hurt the pump tho.
