OMG VERY URGENT ***WRONG GAS***
Trendwho205
Car: 2007 Infiniti M45 Sport
so I left my girlfriend my car 4 today and she made a mistake and put 87 octane gas in the car she actually filled the tank is this going to be a problem for my engine I have a 2007 Infiniti m45
Mjkkb2
Car: 2018 Infiniti QX60 AWD
2011 Infiniti M37S
2011 Nissan Quest
2001 Infiniti I30t(sold)
Don't fret, You'll be ok. Check this discussion.
wrong-gas-in-my-m45-oh-no-t584702.html
fat3oy
Car: 07 M35X, 06 350z, 06 RSX, 99 Dajiban
totally fine... I've done it a couple of times when tired... as long as you dont have some wonky tune, F/I, or a track day coming up you'll be cool. If you really want peace of mind throw some octance booster in the tank till half a tank then filler er up with premium
GQM45s
Car: 2008 Infiniti M45 Sport Tech Pkg, Advance Tech Pkg, Mobile Entertainment Pkg
at least it wasn't diesel......
fat3oy
I would have put diesel in mine multiple times if the nozzle fit... I should pay more attention I suppose...
The00Dustin
Car: 2006 Infiniti M45
fat3oy wrote:I would have put diesel in mine multiple times if the nozzle fit... I should pay more attention I suppose...
And definitely never buy yourself a diesel. I believe putting gasoline in a diesel engine is more dangerous than putting diesel in a gasoline engine.
vasekvi
I've seen both occur lol.
fat3oy
Indeed, I have a diesel van... thank god I have never been so careless as to put gas in...
szh
Car: 2018 Tesla Model 3.
Trendwho205 wrote:so I left my girlfriend my car 4 today and she made a mistake and put 87 octane gas in the car she actually filled the tank is this going to be a problem for my engine I have a 2007 Infiniti m45
As others had said, this will not be a permanent problem to be concerned about.
Just drive gently - without hard accelerations (try to avoid the pinging ... that is a sign of engine knock being prevented by electronics!) till you get a chance to re-fill with Premium. Be gentle for a tankful or two.
Z
ale2and
Car: 2008 m35s
We have an 08 m35s. Is it a problem if we use 87 octane. It says premium recomended not required. Are we going to hurt or car?
kmiles
Car: 2015 Q70 3.7 AWD - Hermosa Blue
Sold - 2007 M35x
I have an 07 M35x and buy 87 octane at Costco whenever it gets above $4 per gallon. I haven't found it makes any difference in gas mileage. I asked a technician at Infiniti for his opinion and he said as long as it doesn't ping, I can run 87 octane, but it may get build up on the plugs and injectors faster than if I used high octane. When it gets above $4 I buy every other tank low and high.
The00Dustin
ale2and wrote:We have an 08 m35s. Is it a problem if we use 87 octane. It says premium recomended not required. Are we going to hurt or car?
Recommended means lower octane will affect performance (where it actually doesn't on most cars). Required means lower octane could cause damage (but, according to the manual, driving gentle can prevent that damage if you must use a lower octane because no proper octane is available). You should be fine running 87 in your m35s this thread was started about an M45 because the M45 has the "required" terminology.
Larz
Car: 2019 Q70-L RWD
About two years ago I was on a trek through North Carolina on my way home from a match in Virginia. As usual, I wait until I really really need to stop for fuel and this time, I ended up at the only station open in the middle of the night and every pump was Ethanol fuel. I had no choice coz god knows how many miles I would have to drive to get to another station, so I added just 3 gallons to get me back on the motorway. It did no damage, and I topped off with 93 at the first station I could find. I also have to say ... if you don't want to pay an extra 5-10 pence per gallon, why didn't you buy a different car that actually runs fine on 87? To me, if you buy an M, you should be prepared to pay for 93 octane fuel and maybe save money by driving it less, or more gently, or cutting back on other things to negate the added expense of the fuel. One less night at the pub per week, or one less extra pay channel on your cable bill should do that nicely.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
GQM45s wrote:at least it wasn't diesel......
OP, Too funny!!!! I was thinking the same thing.... NO NOT DIESEL :crazy: but really, it's no big deal.... Just go back to your routine when this tank of gas goes low... You could drop in an octane booster in the gas tank also!
