OMG the second transmission i have put in is bad?
texml69
Car: 1993 J30T gold package
ok so i got another transmission with 71k miles on it put it in filled it up and it seems to be stuck in a gear when it starts in park it jumps forward and the revs wont go over 2k. no reverse and no at light/ so i changed the n.s.s. with one that came off my old transmission i know it is good and still no a/t light procedure? also the transmission seemed to get extrmely hot only ran bout 5 min and was so hot on the pan could not touch it :cry:
any advice here im pulling my hair out with this thing
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Does the oil pump work?
Is the oil cooler and or filter clogged?
Did you test every sensor and make sure it conforms with the specs in the service manual?
Did you read the service manual at all?
Nicoclub.com/FSM
driverdriver
Car: NICO's longtime resident Canuck!!!
Did you overfil the transmission fluid?
Overfilling the transmission makes it run hot and cooks the transmission.
texml69
nope its right at full and was told it was out of a running car maybe the torque convter came unlocked when i put it in??
would that cause this problem?
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
texml69 wrote:nope its right at full and was told it was out of a running car maybe the torque convter came unlocked when i put it in??
Sounds possible. If you miss that last click the pump might not be fully engaged. In either case it sounds like you have to pull that back out (I am so sorry I know how much that sucks, been there done that)
TPS check might help. :gotme
What happens when you shift from park,
Is there the feeling of torque engaging?
If not your hold pressure might be low....
Any Puddles?
texml69
Any Puddles?
When it starts in park it lunges forward a little and you can not get the motor to rev over 2k rpms like its in gear and park at the same time :cry:
has no reverse there are no puddles under it and i changed out the nuetral safty switch and still cant get it to give me any codes :mad:
texml69
deathofisrael wrote:Dont know about infiniti transmission's , but not having the torque converter locked in right can blow your front pump in other transmission's..Ive done it .not pleasant .I did it to one i rebuilt. ..I was always taught , never run a transmission used without a rebuild first .even if running when pulled . You take big chances when going on the cheap sometimes ..That's my take.
yeah thats true but when a rebuild cost 2800 bucks and the car is worth say around 1500 you dont do it !! :tisk: you cross your fingers and hope for the best lol :yesnod
yodawill2000
Car: 94 Infiniti J30
"I was Diamondj30 who got banned without warning for never attacking anybody"
Not sure but I doubt SERIOUSLY Diamond was banned.
He is a true jem and an asset to NICO.
:wtf2:
goody90q45
Car: 1992 Infiniti Q45 (sold)
deathofisrael wrote:Yep , transmission's are way expensive ..Drag for sure .
on the other hand;
Well , here i am .. I was banned litterally..i could only get back in because nico switched up and left me a hole .lol. Look at my last post and login under diamondj30 , then wonder why.........
I could personaly care less about politics, but NICO does have rules and your signature could get you in trouble again. You might think about inserting something car related and avoid political statements in your sig and posts before a mod hits the ban button again. Welcome back.
Infinitiguy19
Isn't that the kind of talk that got you banned?
After all this is a Nissan/car forum so that talk doesn't really belong here. And plus Nico doesn't have many rules and like I said if you apologize for what every you did intentionally or not you may get your original account back. If not then keep low or move on.
Sorry you have to hear this from me.
Infinitiguy19
I was sorry because you are a member of a Nissan club before I know how cars worked. And basically NICO originals don't like taking crap from newbies. I am not trying to be a dictator either I am just saying whats in the Terms Of Service, to protect you from another Ban hammer.
Plus some people now a days get mad about the dumbest things and sue people for the dumbest reasons. For instance I worked at Stop and Shop when I was 15 years old and I was a cashier. I was pretty stupid back then too and I saw a produce guy write "Produce GOD" on his name tag. So I wrote "Front end GOD" on mine and a guy buying groceries says "your a GOD", I say "no its a joke" the guy gets mad and cries to the manager and I get slapped on the wrist.
So there you have it I didn't know the rules back then but it was either get a new name tag or get fired for something stupid. So in your case you can suck it up and change your signature or see what the NICO staff does.
yodawill2000
Man o Man
I must have missed something.
Cant believe anything you would say would cause a ban.
You Roxer.
:dblthumb:
texml69
:inout: well im going to go see what i can do on this friday how do i test all the electrical????? im thinkin its in the linkage cause i cant get it to read codes and the alarm wont turn on it? i think it is not getting fully into park like its in reverse and park at the same time?? is that possible ? :wtf2:
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
texml69 wrote::inout: well im going to go see what i can do on this friday how do i test all the electrical????? im thinkin its in the linkage cause i cant get it to read codes and the alarm wont turn on it? i think it is not getting fully into park like its in reverse and park at the same time?? is that possible ? :wtf2:
At the point when the car starts and lurches (it was somewhere before it all went to hell) it is in gear...and it doesn't know it. Honestly IDK where/what it could be but start with the basics but more likely than not it something directly related to the gear position. I have seen one guy once a while back put a trans in and misaligned the actual selector on the case and it wasn't right and he thought it was blown. Did you by chance adjust or have a problem with the linkage did you? I have actually put my car down on the shifter linkage
while it was hanging down and made a huge mess.
Crap happens go back to the beginning and check everything that would have control of gear position. Hopefully it is something simple like misadjusted linkage but it doesn't sound too electrical.
Will- gotcha, I was uninformed.
texml69
yeah i though about that to but i s*** it under neath b hand with out the likage on its was the same so took it to a transmission shop and they are saying that the forward clutches are fused to the shaft or something to that affect in short the transmission is junk :cry: so i guess i will be pulling the transmission again :nutkick
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Man I hate to hear that your trans is shot.
This type of repair and diagnosis is a lost artform. Is there a warranty on your trans? If not are you planning on getting it rebuilt? Do you still have two?
I have seen this type of thing all to commonly with recycled parts engines and transmissions are the worst things to gamble on. Although they are cheaper in the long run at some point you start to question just how much your time is worth.
First beers on me today man, I know just how bad that sucks :cheers:
texml69
SteveTheTech wrote:Man I hate to hear that your trans is shot.
yeah it has a 30 day warranty on it so im coverd there its just a matter of pulling it again hopefully third times a charm ill keep you updated :bigthumb:
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Glad you've got a warranty on it. Still a large heavy PITA though that I am sure dragging a dirty ole RE4 get's old fast.
texml69
SteveTheTech wrote:Glad you've got a warranty on it. Still a large heavy PITA though that I am sure dragging a dirty ole RE4 get's old fast.
yep that it is if i get one more auto that dont work im doing a Manuel conversion lol
