maxima278 »
https://forums.nicoclub.com/maxima278-u20438.html
Fri Oct 21, 2005 12:28 pm
personally, I think you can do custom work to a car and have it not look like rice, but there is a fine line to ride there. The S14 body looks so good just like it comes, zenki or kouki, front or rear. The S15 front looks good only when done right, and the other front ends look so good, it seems pointless to me unless you have a damaged front end and even still the cost of changing to another front end is prohibitive in my book. If you're going to change an S14, just lower it, give it wheels with a nice offset, pick out a nice front grill, and maybe a mild body kit if you aren't happy with that. Anything else will take money away from an engine swap, and other things that will make owning a 240 so worth it.
I do think the S13 body lends itself well to front end conversions though. The S15 front looks really good on a hatch and the silvia front is mandatory for a coupe. For the hatch, maybe a wide body and some 180sx tails, but not even a noticeable wide body, just enough to accent the s15 front, then for the coupe, that silvia front is plenty.
In theory, the price difference between an s13 and an s14 should be enough to offset the cost of the front end conversion on an s13, so if you're with my way of thinking it all evens out.
