alphapig wrote:Ah, I think I know your problem. Sounds like you did not tighten the master strut bolts (whatever they're called) all the way. It's number two on this pic:
Open your hood and look at the master strut bolt. There's two, obviously, one on each strut. The bolts have one of those Torx (star pattern) sockets on top of the threaded section.
What you need to do is use a Torx socket to hold the strut in place, keeping it from spinning, while you tighten the actual bolt (#2). If you try to tighten the bolt without holing the strut in place with the Torx, the strut will just spin and it won't tighten all the way.
Make sure those are tight. Even a CM worth of thread left untightened will make terrible knocking noises.
Hope that helps...
There is noise only during driving, esp bumpy roads. Its more of a rattle than a hissing or springing sound....I called eibach tech and they said, as long as the clear plasic tube is on the springs at the bottom, no noise should be coming from the spring itself and i should check all the bots again, esp the strut hub.
So I checked again and everything is 500lb impact wrench tight... except bolt #2, the middle one. It spins and spins. I asked a friend, and he said it supose to be... but I guess i'll take your advise and use a Torx socket to hold the strut in place, keeping it from spinning, while you tighten the actual bolt. This was the first thing in my mind when I heard the noise.. but my friend convinced me otherwise....To bad I don't have a Torx socket. Quick question... Do I have to remove the whole struct/spring or can i just tighten them while in the car?
Also, if you look at bolt#2, I do have about same amount of bolt showing as in the picture, about 1 cm - 1.5 cm. Before I installed the springs, that bolt was so tight i had to use the impact wrench, but now it spins so easily.
Lastly, I used to get a hishing sound when i turn left, even when I am not driving.. but not its gone after a short drive... atleast one probleme gone...
Thanks for all the inputs. I'll keep you guys posted.
