OMG i cant believe i missed this!!
daniel240
Car: cars/motocross
the other day while driving i noticed i was loosing power as soon as i started boosting. i assumed it was a leak in the ic piping because they always blow apart. so i took it all apart and found a big hole in one of the rubber couplings holding them together. so i replaced that and while i was putting it back together i noticed there was a threaded hole on the compressor housing on the turbo. i must have not seen it when i put the turbo on. its for a wastegate signal line, but i have mine running from the ic. so i plugged the hole, and took out my car and it was 10X's faster. and spools up much faster. i cant believe ive been driving around for weeks with that hole unplugged. but it still didnt fix my stalling problem like i hoped it would.
j-z
Car: 95 240sx
lol, you learn from your mistakes
candela
ahahah thats pretty funny! Are you venting your BOV? If so, try recirculating it... it may fix yru stalling probelms. Vacuum leaks elsewear? Try making a leak tester to see, cause not all leaks are visible.
huguetpj
Car: 93 KAT Coupe
Homer says: Duhhhhh!!!!
And that is one big *** leak right there :D
