deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Mon Mar 28, 2005 8:32 pm
Haha, Um, well.
There is much more to learn than what I could tell you about resonance and harmonics. The theory is quite extensive and complex. Ill see what i can dig up for you as far as reading material.
All of my work and research has been very specific to the particular build, many of course. Its hard to offer much of an answer without a question.
Better is somewhat of a meaninless word in the realm of engine/intake/exhaust theory and design. Variables can be manipulated almost infinitely to produce different results in different ranges of use. It is best to first have some sort of idea of what you are after, with what is available to you. Some copying of other designs becomes key and also teaches you at same time.
Standalone management is simply electronic fuel injection that provides adjustment in real time of all fuel injection/ignition parameters and others. It allows the tuner to dial in the most efficient control settings for their engine ("efficient" for most, meaning most effcient way to make HP with heat in concideration, not necessarily efficient at burning fuel). Necessary for any modified efi engine to make the most hp is a properly setup ecu, do some reading on the subject online.
Id be glad to answer any specific questions you might have about ka design, but get some first, .
