autoworkz wrote:...the torque curve isn`t a curve at all, it just starts. we even tried start to record the run as low as 900 rpm and it`s still up there, almost a straight line from start to finish. stinky has resocketed the ecu and will probably start the tuning tomorrow. i`ll get dyno graphs up soon.
The VH45 was designed to provide 90% of its torque from 2000 rpm.
I sent away for the SAE paper on the VH45DE and there is a Power Output chart. It shows that at 800 rpm there is almost 240 ft-lbs. of torque available.
The chart shows that the torque curve is pretty linear. It starts at 240 @ 800 rpm, peaks at 292 @ 4000 rpm and finally dips to 225 @ 6400 rpm where the chart ends.
Of course, if the engine was tested with the VTC disconnected, as many have stated, then the numbers would be even higher.
