Megaseth wrote:even then, you cant spark it. they use glow plugs, kinda like a spark plug, only they get really hot. when the fuel is compressed to 16/1 or so(for a way smaller engine) the plug provides the heat to ignite the mixture.
In a Diesel, only air is compressed. Fuel is not injected until the end of the compression stroke.
Glow plugs are only used for starting and warmup. Once the engine is hot, the fuel burns pretty much on its own, as it is injected directly into the cylinder at near top dead center, into air that has been compressed mad hot (more than 18:1 CR, plus turbocharging)
I'm not merely speculating diesel combustion looks like a flame thrower. I've seen it (via slow motion photography and a glass cylindered diesel)
