Old school Datsun question
Here you'll find topics regarding the Datsun B210, 310, 610, 710, 810, 1200, and lots of other models - All are welcome!
frapjap
'07 Subaru Legacy
There isn't much action on the other part of the board soooo...
What did the L24 and L20 cranks come out of? Car, truck? What year(s)?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Datsun 810 and Maxima had an L24 from 1973 to 1984.
frapjap
'07 Subaru Legacy
Those were 4 cylinders, right?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
No, the L-series was a straight 6--the same motor from the legacy Z-cars.Forgot to mention the Z cars before, sorry. L24, L26, and L28 in those.
frapjap
'07 Subaru Legacy
What is the older 4 cylinder crank called/what did it come in? 510's?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
There was the Z-motor, in 2.0, 2.2, and 2.4 liter guise.
frapjap
'07 Subaru Legacy
DUH. and that came in 510's right?
frapjap
'07 Subaru Legacy
What I'm trying to get at is if the Z24 and Z20 cranks are interchangeable in the 2.4l block.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
The Z-series was only in the 200sx and Pickup (720).
Ahh, the 510. Now I see where the confusion comes from. It had an L16, but it was indeed a 4-cylinder.
The 510 L motor is really a Z block with a different cylinder head.
I don't see why you couldn't swap the Z20 crank into a Z24 block.
EDIT:By the way, I'm not quite as knowledgeable as I appear...I've been cheating on the 510 motor info:http://www.datsuns.com/Tech/datsun_engines.htm
frapjap
'07 Subaru Legacy
MinisterofDOOM wrote:The Z-series was only in the 200sx and Pickup (720).
Ahh, the 510. Now I see where the confusion comes from. It had an L16, but it was indeed a 4-cylinder. I assume it was just a shortened version of the larger L...?
Thats my assumption too. I was pretty sure it was possible to interchange the 20 and 24 cranks in the 2.4l block for a larger/shorter stroke. Massive confusion... lol
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
That makes sense to me.
In case you didn't see my edit in my previous post, check out http://www.datsuns.com/Tech/datsun_engines.htm
BUT, seems like they're not entirely accurate, as they show a VG30i in the photo labelled VG30E. Not THAT big a difference, but certainly enough to notice.
I'm sure Bandit240 could provide better input.
frapjap
'07 Subaru Legacy
Thanks for the link, I did catch the last edit. I was getting really confused because I could only find hybrid things on the 'net and no positive source. That, and I forgot the Z designates 4 cylinder. I got confused and for some reason related the Z car with 4 cylinders. Moron....
Thanks for all the help! I'm so bookmarking that site.
datsunb310
Car: 1980 datsun 120y (b310)
the engine out of the 510 is the L20B 2000cc.also came in the japanese spec maxima(bluebird) and the 810(bluebird 200B).the 6 cylinder L series came in the cedric/glorias,laurels and the early z'sas well as the us maxima and 810 as mentioned.
the l24 is out of the 240z maxima and 810.below is a australian spec datsun 200b
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
No offence guys, but if threads like this are not in a "low traffic" section, there will never be any traffic in the section.
Thread Moved. Thanks MOD for you help to answer this question.bud
datsunboy
Car: Datsuns
the lot of you sound rather confused!
the 510's made between 68-73 all had an L16. (4cyl)ALL zeds....240/260/280 all had 6cyl L-series....either a L20a, L24, L26, L28, L28ET.
there are a few versions of the L20 engine.....
L20A - 6cyl carbed ( JDM 200Z...same as a 260Z, but 2.0l )L20B - 4cyl carbedL20E - 6cyl EFI L20ET - 6cyl EFI Turbo ( early skylines )
how can the L series have a Z block????the L came first.....so really....the Z has an L-Block.and YES you can swap cranks between the L and Z motors. ( with the bigger cranks like Z24, you will need to do some machining to get the counter weghts to clear ).
You can even swap Z heads onto L blocks and vice versa.Z series motors were all 4cyl......and came in 180sx, 200sx, trucks, and 910 bluebirds
Return to “Other Datsun Cars”
