scheffler »
https://forums.nicoclub.com/scheffler-u26265.html
Thu Oct 18, 2007 7:42 am
yes you are right it iterceptes the maf signal and changes it to add or subtract fuel. I have a enthalpy tune for timeing and all that stuff. I just need to add some fuel to trim my AFR.
Ok on the back of the unit it has 7or 8 dip switches for maf select then it has a circle dial with numerd 1,2,3,4,5,6,7,8,9,a,b,c,d,e,f or something like that( sorry i am work and dont have the unit hear)for your car select so you input the maf and the car. I need to know the car select input. So if someone has used this before what was your car select.i have all the other info that i need. I guess i will just play with it till i get the right one if no one has this info.
