OLD MAN EMU 1.75" or AC 2" Lift Kit which is better?
xtremexterra
Car: 2003 QX4
I don't know which one to get. Old Man Emu offers a 1.75" lift kit with a Front 9/16" lift Trim Packer. Or the 2" AC. I want to put a lift on that avoids the rear end of the suv sitting higher than the front.
I noticed that there is are two types of coils offered "heavy" and "medium" does anyone know if the ride height is different between the two coil choices?
What do you guys think would be better in ride quality?
Could I buy the front lift trim packer from old man emu and use it with the 2 inch AC lift kit?
Any suggestions would be great thanks!
fueler
Car: 2 Nissan's
2 BMW's
medium should be the softest of them all. (but still harder than stock). i suggest u go with at least the heavy, ive seen the medium and it isnt that much taller than stock
" I want to put a lift on that avoids the rear end of the suv sitting higher than the front."
i know what you mean. i hate that "angry stinkbug" stance that some lifts give. I think OME rear springs are like that.
xtremexterra
Car: 2003 QX4
Thanks for the info. Its going on my 2003 QX4, does the AC 2" lift it enough to put a 265/70/18? I wanted to use a Nissan Titan 5 spoke wheel? I heard I might need to bore out the center hub of the wheels.
fueler
Car: 2 Nissan's
2 BMW's
yea u just have to bore tire size is a 32.6" i think it can be done with minor trimming as long as the backspacing allows it people have fit certain 33's with the AC lift and trimming
InfinQX4
Car: 2000 QX4
xtremexterra wrote:Thanks for the info. Its going on my 2003 QX4, does the AC 2" lift it enough to put a 265/70/18? I wanted to use a Nissan Titan 5 spoke wheel? I heard I might need to bore out the center hub of the wheels.
I've been looking at the OME or AC for my 00 QX4. I'll be interested to know what you go with and the results. I like the idea of OME because it's a little less stress on the CV joints, but I don't want the front to sit lower.
Also, my mechanic suggested putting extended brake lines in the back. OEM left enough slack in the front for a lift, but he thought the back might be a little tight. Has anyone done this?
jimmyzzer
Car: 1999.5 nissan pathfinder
the front brake line stays in the same place just the spring height changes.the rear brake line is long enough even at full flex.the only line you have to extend is the vent hose on the rear axle.
xtremexterra
Car: 2003 QX4
I called Rocky Mountain Suspensions who sells the OME kit, but the guy on the phone was no help at all. Does anyone have a pictures of the stock coils next to the bigger coils?
jimmyzzer
the springs are going to look alot taller.they sit a little high for about a month till they settle down.
xtremexterra
Car: 2003 QX4
I called Rocky Mountain Suspension again and got a guy named Glen who was so much more helpful than the other guy. I decided to go with the OME suspension with the trim packers in the front. This should give me at least a 2 inch lift in the front, and 1.75" in the back.
Has anyone posted a detailed "how to lift a pathfinder" in the past with pictures?
InfinQX4
Car: 2000 QX4
Are you going Medium or Heavy Duty?
screwinitupagain
Car: 1997 Nissan Pathfinder SE
For comparison's sake:
Stock hieght
2" AC lift (which is actually like 2 & 2/3" after it settles)
screwinitupagain
Oh yeah & the stock height is with 31x10.5's 7 the 2" lift pic is with 32x11.5's
jimmyzzer
same as changing the struts for the front/the rear just coils and shocks.
xtremexterra
Car: 2003 QX4
I think I am gonna go with medium. I really want the QX4 to have a nice ride, but someone told me that the heavy coils make the vehicle sit slightly higher than if you were to buy comfort or medium. Has anyone else heard of this?
screwinitupagain
xtremexterra wrote:I think I am gonna go with medium. I really want the QX4 to have a nice ride, but someone told me that the heavy coils make the vehicle sit slightly higher than if you were to buy comfort or medium. Has anyone else heard of this?
I have the AC 2" lift with GR2 struts & Rancho 9000xs (or is it sx?) & it rides better than stock. Its all about the front struts & rear shocks when it comes to the ride quality.
lemansz20
Car: 2004 Nissan 350z
Where canyou purchase this stuff???
xtremexterra
Car: 2003 QX4
http://www.4x4parts.com for the 2"lift
google "rocky road suspensions" for the old man emu lift
screwinitupagain
The "heavy duty" coils on AC's site are the Old Man Emu coils
cfuqua
Car: 1999 Nissan Pathfinder SE
I currently have a 99 Pathfinder SE. The only lift kit thats available is the Old Man EMU, but its only a half inch???? Are there any other avenues i can go down???
Thanks
Wildpeakr50
Car: 1998 Nissan Pathfinder
cfuqua wrote:I currently have a 99 Pathfinder SE. The only lift kit thats available is the Old Man EMU, but its only a half inch???? Are there any other avenues i can go down???
Thanks
The ome ones I found and they offer 1.75 inch lift but there website is confusing haha
rocky-road.com This is were I found them
Wildpeakr50
Im thinking of going with the top strut spacers myself I just got my 98 set pathfinder and want to put 31s on it :)
