Old girl gets new shoes!
D21hardking
Car: 1991 D21 Hardbody King Cab 2.4L 2wd
1997 D21 Hardbody XE King cab 2wd 2.4L
Bought my 97 a used set of 17" x 7.5 rims! Was worried about the fit due to the offset, but all worked out. Just need to get hub rings ( already ordered). So they're 17x7.5 with an offset of +35 with 235/55R17 tires. Throws the speedo out by about 5kph or 3mph (@100 kph/60 mph). No spacers required! No rubbing up front on full lock turns! They're not high end, but they work for me!
Project510
Car: 1997 Nissan Pickup XE 2WD
Curious what hub rings you purchased. I couldn't find a set that fit correctly.
D21hardking
The hub center on the rim was 110 mm, couldn't find an exact match of 100mm to fit truck hub, best fit was 100.3mm. Doesn't seem to mind it though. No vibration at any speed. If I can find the invoice, I'll her you know whee I ordered from
Project510
I found the right size for my wheels.. 108 to 100.3 but everything I find is chamfered on the face that meets the truck side so they just slip off the tiny edge.
