okayyy ca problem
s14danny
my car wont hold at idle anymore just dies shortly after i was thinking maybe the cas or coil? f*** it was running perfect last night and i never really rag on the b****.
reminds me a little of this one
http://www.youtube.com/watch?v...annel
zero_gripS13
Car: soon to be 95 s14 hopefully
vacuum leakbad fuel pump
most common..
will it run with ur foot applied on the gas.. but stall when u let off the gas if so check you interc ooler pipes and couplers sounds like a vacuum leak... if it wont do that remove the feed line to the fuel rail stick it in a bucket and have someone crank over if lots of fuel comes out its something else if lil its fuel pump..
hope this helps.
