NEED4BOOST »
https://forums.nicoclub.com/need4boost-u4386.html
Thu Oct 09, 2003 2:38 am
***Please read***........sorry for the length just trying to give as much detail as possible.
Okay guys I've had my s14 SR in my car and running strong for about 3.5 months. I have only driven it for a total of 1,600 miles!
In mid september I went to VIR to run the car and work out some bugs (suspension, and driveability). Anyway at the end of the weekend I ran into the biggest problem and that was an exhaust leak that ended my fun for the weekend. I pulled of track and slowly drove the car back to the trailer and checked everything, let the turbo cool, and packed up the car and got ready to go home.
Well the next weekend I limped the car over to my buddies house which is 3 miles from mine so that we can work on the car and find out where in the hell the exhaust was leaking. The exhaust was leaking right where the manifold bolts up to the turbo. The gasket was blown. We tried to tighten what we could reach until the gasket kit came in. After we finished I drove the car back home (with the exhaust leak) and half way to my place I began to here the valves, not too loud because I was keeping the revs under 2000rpms. So I assumed that they were just noticeable because the exhaust leak.
The car sat for a little over a week and then last night was the first time I fired her up and got ready to drive it to my buddies house so that we can put the gaskets on. Well when I fired up the car the valves chattered for a couple of seconds and then got quiet. When I drove it I heard them like before.
Took off the manifold, turbo, etc and put everything back together, fresh oil and coolant/water. Built up oil pressure to circulate to the turbo and the rest of the block. Pluggged in the ignitor chip and fired up the car. No valve chatter but the when the motor revs to 1200rpms you could here them. I let the car run for a few minutes. Drove it around for a little bit to see whats up. Boosts fine (boost controller turned off), no hard pulls or anything. But I could here the valves but not as bad as sitting and reving in nuetral. After a couple of minutes of driving and getting to my place, I decided to rev the motor in nuetral. The valves didn't chatter until 2k rpms.
I don't understand whats going on. Could it be that these valves are self adjusting? Do my valves have to be tightened/ retorqued? Or is the valvetrain shot?
As always, thanks guys.....
