Okay to cap off these lines?
op.tic
I was cleaning the throttle body on my ka24de-t and noticed these lines werent connected to anything, 3 of them were already capped, but the caps were split so i went ahead and just capped them all with new vacuum caps.
Also noticed this line on the throttle body itself, wasn't capped or connected to anything so i put a cap on it.
480sx
Car: 1996 Pearl White 240sx
Its fine to do it that way. Its a bit better to take all the emmisions stuff off, less chance of boost leaks on your intake manifold.
driftnslide1
Car: 92' 240sx coupe/ 87' toyota supra turbo
those four lower ones are for the charcoal canister. so if you are capping those make sure the ones going to the charcoal canister are also capped. go ahead and put a zip tie on em for good measure.
