NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun May 01, 2005 9:56 am
The pick up wheel in the transmission has the wrong amount of teeth on it, only thing it can be if the cluster is not the problem. The sensor in the trans is a frequency generator. If it generates a wave to fast It will show up on your cluster [ if that makes sence to you]. try another pick up is all I can reccomend. Do you know anyone with a 240 you could borrow it from? First do this, disconnect the pick up on the trans[attached to the tail housing of the trans on the right side] and drive it. If it gives a speed reading it is getting its signal from somewhere else. that is a whole different can of worms if it does do it.
