ReaperBJJ »
https://forums.nicoclub.com/reaperbjj-u82304.html
Sun Apr 20, 2008 6:28 pm
I know you said you checked all the fuses, but did you check the big 75amp fuse in the box next to the stock battery location? I had a problem similar to you, and looked for shorts and tested everything for days, and the fuse passed the visual test at first glance, but I took a multimeter to it and had no continuity and say that there was a tiny tiny tiny split in it. So I went around and ended up having to get a replacement at the Nissan Dealer for $23, but it fixed everything and I had problems very similar to yours.
