Here's a few of Dennis' older posts I found
Q45tech wrote:IDEALLY Replace the oem rear subframe or just use/modify 300zx parts........and accept the downsides of extreme vibration transmission to body.
Changed my rear subframe when I replaced the diff [due to noise/lack of LSD action] at 235,000 miles [12 years typical life] took two of us 5 hours with a lift and flat transmission jack table and every tool imaginable. Tricky.
Silicone filled bushings are available [from some dealers] for one size of front Q tension rod assembly. Solid ruber and urethane will fit certain sizes.
There are differences between the standard and active Q front tension rods also some TSB versions for caster differences........one size on left different on right.............
Excerpt
Q45tech wrote:... I just flip my trimode to 2nd gear start and proceed with my almost brand new LSD [55k]...........the 20 mm rear bar and Eibach's mean you must avoid abrupt changes in low traction enviroments....
Q45tech wrote:$20 [BG zinc additive] compared to $2900 for a new diff plus labor or $350-$500 plus labor for a used one [that may be worn out [the viscous].
$50+$20 every 2 years [30k] is cheap!
^^ Appears additive is not for viscous LSD, just "rear" ^^
Q45tech wrote:The Nissan Quasi LSD [viscous type] is sealed and need nothing special in the way of LSD additive, unlike most American cars which use clutch type LSD. The Nissan viscous LSD can function nearly as new for greater than 100k unless overheated by spinning tires [on car tire balancer errors] or stuck in snow [but cold so less likely]. Most last 150k or better.
The diff gears need the extreme additive protection of BG concentrate. Unless diff fluid is changed annually..........I use and do both for insurance.
Hope that helps.
