ok trying this forum first before movin on.....
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
I check the sticky in the suspension forum and it has the S14 stock spring rate listed as 2 kg. Does this seem kinda low, or do all the aftermarket suspension parts really increase the rate by that much? Reason I ask is cuz Silkroad will make coilovers with custom spring rates. I would like to know what the stock is in order to know what I need to order spring wise.
Thanks in advance
Jason
chmercer
hybrid_flyer
chmercer wrote:8/6
8/6 stock????? uhhhh I know its not that high
Red coupe
Car: 92 Nissan 240sx Coupe
8/6 is kts, wich is way stiffer then stock. Id belive the 2/2 most aftermarket springs are only about twice that.
whiterps13
Car: white LE hatch
8/6 is the standard silkroad spring rate, but you can custom order them with 10/8. i would imagine stock is close to 2, but im honestly not sure.
