sandor »
https://forums.nicoclub.com/sandor-u10178.html
Sat Mar 13, 2004 3:27 pm
I guess the memory erases when the ignition is turned on and the ECU tests the systems. I tried to pull the trouble code with the car running today--it won't flash at all. When I turn the car off and the ignition back on, I get the same "55" (which the FSM says is no problem found) Is there any other way to pull the code with it running? I hate to go to autozone, but they might be able to help.
Any other ideas?
