S0lid_Snake »
https://forums.nicoclub.com/s0lid-snake-u47130.html
Tue Oct 24, 2006 9:14 am
next time you test pour some engine oil down the spark plug hole before you put the compression tester in to see if that improves your compression any. if it doest then your rings are likely worn, but you would have to change them anyway eventually, so i say boost away
