slw240sx »
https://forums.nicoclub.com/slw240sx-u528.html
Thu Apr 17, 2003 6:39 pm
ok, today we set out on our mission, to get the car to run and not sputter or backfire and not give up on use when warmed up .... part one test the TPS,all ground resistance to see if bad, change coolant temp sensor, again..... tore off the timming covers and water pump pulley, check to make sure the timing at the crank and cams was infact correct and not fuked up ... the shop this motor came from was that bad!!!the timming was on the mark... warmed up car set timming to 19-20deg advance... has crap for low end,... it barely wants to move till you get it into turbo spool territory, doesnt have any torque doesnt want to spinn the wheels.. we drove it around some got some wire connectors and various other crap to clean up the install.. got the car back into the garage.. and proceeded to rewire the O2 senor, correctly this time... also wired up the AF correctly ... rewired the EGT gauge with better grade thermo wiire and connectors... put in my manuall boost controler.. gapped plugs down to 32.. from 39-40 they were at... the car was running pretty good... the AF reads that its lean.. but i think the gauge has a ground loop and is being infected .. every time you mess with somthing that puts load on the electrical system the gauge changes up....EGTs are staying around 1250F-higher 1300F deg , under full throttle and boost... which is a very big improve ment over the other night when i retarded the timming back to the stock 15deg btdc.. so now i think its on to the fun and scary part, tuning!!
there are a few things i need to know before i go any further, and this is where you guys with actuall on hand experiance with these motors should chime in!!! TMS, boostboy, anyone else....
ok 1) im at 20deg advanced .. is it possibly safe to keep goin say to 23-25 degs???
2) whats a good gap to run when pushing 10psiwill 28 work??
3) on the MAF there is a plug to alter AF mixture.. had anyone tryed to use this to richen or lean out the car??which way is which??? we spun it 360o and it seemd to help alil but we dont know which it did lean or richen?
4) we couldnt get the idle down... has anyone taken the AAC valve apart?? is there a spring that goes to it??also the ficd thing does that make a click when unpluggin and plugging it back in? this idle gremlin had me strugglin
5) anyone know if the wrong tps for the car can cause bad throttle response or power reponse down low ... i dont think this is the right TPS the ohm measurements didnt match to the FSM specs!!
thats all i can think of right now ill just post more as i think about it all...
jon
