because i currently am in possession of a VQ30det out of a Cedric (wrecked)
and I plan to swap it into a s14/s13 shell, which ever is the best bang for my buck.
the reason i want to know the differences between the motors is because, i have seen many a swap threads on vq35's into s-chassis but hardly any vq30's. I figure if i could find the motor mounts and everything for a vq35, i should be on my way. No?
also, the VQ has lost compression, either that, or honestly, Idk It's not turning over or anything. if i'm lucky i get a ticking sound but i decide not to bother with it until i get the s-chassis.
so my plans are;
-remove Vq from cedric
-tear down and replace seals/gaskets, etc etc.
-check if anything else needs be replaced.
-get motor mounts
- get wiring harness
-get custom exhaust. ( will a vq35 exhaust work? )
-and upgrade the turbo. or uninstall it.
Basically this is my first build and i'm jumping head first into it as well. I know i shall be difficult, but I am determined not to quit.
and don't worry I'll have help, My elder brother knows a fair amount about 240's considering he's owned about 7
