motoguy128 »
https://forums.nicoclub.com/motoguy128-u46857.html
Sat May 05, 2007 5:25 pm
I'd expect that the Spec V is using the QR25 engine out of the Altima again. It's masaged for another 20 HP and more top end power compared to the torquey motor in the Altima.
I will admit, the Versa motor has me scratching my head a little. It's a oversquare motor, cut off 2 cylinders, flip it around, tilt it forward 30 degrees, add a counter blancer and and you'd have a descent motorcycle engine for a street fighter. They must be using long intake runners and smaller valves to get the low end and midrange performance. Also, where most companies use vairable valve timing to imrpove top end on a neigne designed more for midrange power, Nissan/Renault appear ot be using VVT to improve bottom end and midrange on an engine designed for top end power.
WIth a different set of heads, I bet Nissan could make the Versa motor into a EPA legal motor with around 160HP without turbocharging... but you'd give up some bottom end.
