Ok, stripped bolt in torque converter. Help
kool-aid54
Car: 92 hatch soon with a vh45 heartbeat
The idiot I got my car from told me it had rod knock. Ok no big deal since I'm swapping drivetrain anywho. I just wanted to get it running and maybe drive it around awhile. I get it running again and take it down the block. Its making a funny squeal and a knocking noise different than rod knock. My buddy said check the torque converter, thats what it sounds like. I checked today with my clicker wrench and the bolts were loose. Unfortunately two of the four are stripped. I got one out. But I can not get the last one out. Now I've tried putting pressure on the flexplate while trying to back out the bolt by prying with a screwdriver. I suppose I could get the grinder out and see if it would fit, and grind the bolt head off.
But I'm guessing worst case scenario is that I have to pull the motor, transmission and all just to put this new torque converter in.
Or say screw it and wait for my q45 donor car. I really leaning towards this one.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
since it wont back out in the conventional way..try the fix it all plyers!...visegrips!..i use them allot man for those pesky stripped out bolts..sometimes..ya just need to walk away from a frustrating situation and get a fresh perspective on it..hope this gave ya a few idea's...good luck
kool-aid54
My personal favorite, visegrips. I will try that.
jeb1517
Car: 2013 Kia Optima
2015 Nissan 370Z
2005 Honda S2000
What size is the bolt? If it's 19mm or smaller, I would use this damaged bolt removal kit from Sears. It worked like a charm for me, seriously. I can't tell you how greatful I am for these things.
http://www.sears.com/shc/s/p_1...6000P
kool-aid54
Sorry I guess I should clarify. The threads in the torque converter is shot. The bolt head is fine. When I try to back it out or tighten it up it just turns. I'm going to try to wedge a very small screwdriver between the bolt head and the flexplate. Thats how we use to do it at H2 plant.
But ya I have the small craftsman bolt extractor kit, it works wonders.
