MaXimaSE »
https://forums.nicoclub.com/maximase-u73877.html
Sat Aug 18, 2007 5:24 pm
ok, well I recently bought a 98 Nissan Maxima SE AUTO w/ 124k on it.. and Im having a few problems with it, so maybe I can get some help with them here..
Ok well here goes
*Inspected 8/30/07 - Put on OBDII and threw CODES P0440 and/or P1448 at the Mechanic
*My radiator drain plug is destroyed, I crawled under the car today to do a coolant flush, and well It didn't go down because of this (I can thank the previous owner for this).. I will need to replace the whole radiator now right?
*Im trying to install a new PCV Valve and Fuel Filter.. I know where the fuel filter is so I should be alright on all that, but when I was trying to install the PCV Valve last night, I was in a weird spot and couldn't get much on it.. but when I took the one bolt off to get some slack on it and I tugged on the hose, The valve was left inside the manifold instead of coming out with the hose like It shows in the Haynes Manual. What should I do??
*My exhaust looks like Its the stock build, and Its really rusted out.. The cat back to the muffler looks really poor, but I didn't see any holes in it. How much would this cost to get repaired ballpark figure ?
*The past week that Ive had this car, Ive gotten a very hard time trying to start it in the morning to go to work. I would turn the key, motor would start cranking but I would get nothing.. It would just die out, the only way I can get it started is by pushing in on the gas and racing it. Im hoping I can figure this out, I got a multimeter today but Ive gotta learn how to use the damn thing first Im using a Haynes manual as reference and the first thing it says to do is check the battery with a multimeter. Im also going to try a fuel filter, throttle body cleaning, and try cleaning up the MAF a little.
*Ok, when Im driving down the road, and I hit certain roads just the right way that have them bumps or dips in them and I can hear a "knock/rattling" coming from the front but I can feel it sometimes when I rest my hand on the shifter, and on my feet when resting on the floor. It also doesn't happen on every bump, only some.
Sorry for all the questions, but I figure Id better ask them all.
Modified by MaXimaSE at 8:35 PM 8/18/2007
