ok so as the topic says im swapping a rb20 into my 91 hatch. ive read tons of posts and different stuff but. its all over the place and hard to get a solid answer.
im going to use the mckinny mounts found here [ http://www.mckinneymotorsports...d-165 ] the basic mount kit. ( the black ones ) so with these i could use my s13 xmember or should i use the r32 xmember?
also is it easyer to get my harnesses spliced ?if i go that way do i have to deal with the speedo and the different electrical problems?
help would be much appreciated.
also if i use the mckinny mounts will the s13 driveshaft bolt up to the rb20 transmission? if i want to get an aluminum driveshaft i would just have to get a shaft for the s13 chassis correct?
also if i get an aluminum radiator do i have to get it for the r32 ( it doesnt say rb20 engine ) and fabricate mounts for it to fit on my s13?
Modified by kydrifting{rdc} at 1:02 AM 9/16/2009
Modified by kydrifting{rdc} at 1:20 AM 9/16/2009
Modified by kydrifting{rdc} at 2:30 AM 9/16/2009
