cdlong »
https://forums.nicoclub.com/cdlong-u11619.html
Thu Nov 10, 2005 9:18 am
you might be able to tack weld each stud in so it doesn't turn.
if you can't get it driveable, you could take everything from the spindle out as a piece by disconnecting the shock, tie rod and lower ball joint.
