True, but that brings up a good question: are the rings that come with forged pistons (eg, Wiseco, Ross, Arias, JE Racing, CP, etc etc) "good" and "durable" enough for boost? If the first thing that goes on the OEM pistons are the rings, I want to make sure the rings I'm using with forged pistons are durable and capable of high boost and plenty of abuse.Structure240sx wrote:most pistons come with rings. go to ka24de.com
Structure240sx wrote:its not the stock rings on stock pistons that are really what is the weak point.
its that the ring lands are so small. if you compare them to an aftermarket piston you will see that they are much much thicker
That's what I'm planning on using...the 9:1 Wiseco's. I'd rather run 9:1 than 8.5:1 especially if I'm only looking for "modest" amounts of power (around 330 rwhp). But yeah, i hear good things about total seal piston rings...my dad runs them with his JE racing pistons in his 11.2:1 N/A alfa romeo engine and has no complaints. I wonder if Rick is using just the rings that came with the wiseco's or if he's using some "better" brand rings...N.O. Accorderz wrote:i'm in the same boat as your are...building a block for a kat but on a tight budget...i found that the "cheapest priced" forged pistons were from Wiseco...i think they were 419 at importperformanceparts.com/net...but i've talked to alot of engine builders and they strongly recommend wiseco
