AWDB12wagon »
https://forums.nicoclub.com/awdb12wagon-u47622.html
Sat Jun 09, 2007 10:49 pm
Im guessing its similar to the SR timing/idle mode adjustments. You just warm it up, hold the RPMS at 2k for 2 min, let the car idle down, then turn it off. Unplug the TPS, restart it and adjust the idle FIRST, because this will have an effect on timing. Then adjust your timing. You then rev it 2-3k 3 times, turn the car off, plug the TPS back in, start it up, then I always rev it 2-3k 3 times once again to just make sure the computer sets it as the base timing.
