goofynick6 »
https://forums.nicoclub.com/goofynick6-u13220.html
Wed Sep 15, 2004 9:39 am
Ok, I thought I'd cured my problems when I found a boost leak, but no.
WHen I first start the car for the first time of the day, let it warm up for a few minutes, and then drive it, it is incredibly fast. Like, it'll hit 4-5 psi with very little throttle load, and when that 4-5 psi hits, you REALLY feel it.
However, after it's up to operating temp and you've driven it for about 10 minutes, it feels totally different. It will take more throttle to hit that 4-5 psi, and when you do, it's barely noticeable. It no longer breaks the tires loose in 1st or 2nd gear and it feels like it has lost about 40 hp..no exaggeration.
So, I don't get it...watching my wideband, it runs the same air/fuel and the boost gauge says it is the same, so the only thing I can gather is that I am somehow losing the timing; something is retarding it. My question is, what would do that?
My timing is at 15 deg at idle, but something is pulling a LOT of timing once the car gets up to temp. Coolant temp sensor doing this? Or what?
ANy opinions welcome! Thanks guys,
Nick
Modified by goofynick6 at 8:06 PM 9/15/2004
