Acecool »
https://forums.nicoclub.com/acecool-u46759.html
Sun Nov 18, 2007 4:29 pm
Hmm, I was told - probably wrongly, it doesnt matter how you hook them up in the back..
The way I did it was, on the ka there was one with a metal pipe in it connecting 2 hoses, I used the hose on the rb that had the sensor it in for that connection, and the other hose for the other...
The engine is warm/hot to touch, and the upper radiator hose is HOT HOT HOT...
The gauge shows a little under the halfway mark (and will not go any higher even if I rev.. maybe my e fans are too good ahahah...)
Coolant I bled - might still be some air bubbles but I let it run, with the cap off, and filled it up as the bubbles came out... ill check that again in the morning..
