kool-aid54 wrote:Sorry I should of specified, I'm looking to do the now popular "vh45" engine swap into my 93 240sx. And I didn't know if there was a huge difference in terms of fitting into the chassis. The prices do vary between them though.
Any motor will work.
Traction control motors have throttle bodies with dual butterflies for the traction control, but if that actuator is left disconnected you're fine.
4 Wheel Steering motors have HICAS PS Pumps. If you plan on using the Mazworx PS kit, you will need to find the brackets and pump off of a 2 wheel steering car.
Active Suspension cars have a PS pump that has a high pressure hydraulic pump built into it for the hydraulic active suspension system. You will again need to find a 2WS pump and bracket. Edit: You will also need a 2WS/4WS crank pulley, tensioner, and belt since the active cars used 7 rib belts on the PS pump and the non-active cars used 4-rib belts. You can probably put the 4 rib belt on the 7 rib pulleys, but it might not be worth the risk.
If getting the pump and bracket isn't an issue for you, than any motor is fine.
No active suspension motors in the US have traction control.
Traction control was a popular option on Q45t models, which all have 4WS.
Traction control was a less popular option on base Q45 models, so most 2WS motors don't have traction control. But not all, my Q was a base with traction control.
Thats probably a lot more info than you need to know. Long story short, any motor can work, PS is the only issue.
Modified by SuperHatch at 2:13 AM 8/15/2009
