ok need help diagnosing oil leakage
streetbikestunta420
Car: nissan 240sx/red top sr20det
ok so i recently hit something pretty hard and all of a sudden my sr starts leaking oil only when turned on, i went under to look but it didnt look like the oil pan was leaking (no damage anywhere), oil seems to be comming from what seems to be a small hole in the block just above the thing the oil pan is bolted to, i cant see it with my own eyes or take a pic because there is no space but i can kinda stick my pinky in the hole (wont fit completly), and kinda feels tapered in (so its stock like that), im 90% ure its comming out of this hole, but i cant tell too well because everything so oily even after i wiped it.. any1 expiriance anything like this?
E7-S14
Car: ess 14 foo!
streetbikestunta420 wrote: oil seems to be comming from what seems to be a small hole in the block just above the thing the oil pan is bolted to,
upper oil pan?
streetbikestunta420
yea but it seems to be comming from a small hole, is there a small hole there? or am i just tripping?
tEknoS13
Car: 93' Type X
you cant take a pic even close to where its leaking to get an idea?
ScrapMetal
Car: 1999 Chevrolet S10
1991 Ford Bronco 5.0
You're gonna have to put that car on jack stands and get under there with a flashlight.
streetbikestunta420
Metaru_Gia wrote:You're gonna have to put that car on jack stands and get under there with a flashlight.
i got it on some ramps, i cant see the hole type thing i gotta use my finger but ill take a pic
allaboutspeed
Car: 1991 nissan 240sx
ITS YOUR OIL SENDING UNIT, OTHERWISE KNOWN AS THE OIL PRESSURE SWITCH...
ashibah83
Car: 93 SUPA BLACK COUPE
allaboutspeed wrote:ITS YOUR OIL SENDING UNIT, OTHERWISE KNOWN AS THE OIL PRESSURE SWITCH...
yeah probably not, if it were the sending unit, oil would be continuosly POURING out, and he said its only happening when he starts it
