elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun Jul 27, 2003 4:10 pm
This week is going to be maintenance week for the Q...... I am at a shop, and there is basically every tool known to man here...... Anyway here is what I have planned.....
Change diff oil- Done..... It was super easy, I have a pump that screws right on top of the oil bottles, just a matter of pumping it until it filled...... And then torque the plugs......
Flush cooling systemChange TstatRemove TB and clean it/semi clean inside of the plenumChange fuel filterChange PS fluid- Also done, I had a really long pump thing that I could reach way down into the hose to get as much fluid as possible......
Ok, now here is the fun part.....
I dont have the right tools to do the TB (6mm allen, thats tommorrow hopefully), so i moved onto the Tstat.....
So here is what my plan was..... Ill take out the old stat, and then flush the cooling system from there...... When I was putting the Tstat cover back on, I broke off the bottom bolt, so a little chunk is stuck inside..... No biggie right, there is a tool to get it out and Ill just get some new bolts...... That is where I am at now, since I was feeling to lazy to figure out the tool..... So ill do that tomorrow......
Question is...... Is it possible I screwed anything up in the process of breaking the bolt.... I think I put it in there crooked, and it misthreaded, and i just kept tightening until it busted, i guess.... I couldnt see it anyway..... I was hoping it wouldnt make a difference, but when I went to fill it up there was water dripping out of the hole......
So..... Do youall have any suggestions for me....... I need to get it back up and running before wednesday.......
