I don't know about the others on NICO but I think a JDM motor is MUCH more powerful than a U.S. Q45. The engine on my 1993 Q45 was replaced while the fuel pump was bad.
The original Q45 engine was smooth as a rock and sure it still had a ton of juice but once we replaced the Q with a JDM motor... it was like TWICE the power, and keep in mind we could not even slightly push hard on the pedal, anything over 3000RPM was nearly impossible, the car would hesitate. In other words the JDM motor had SO MUCH more power in the low end revs without even pushing on the pedal. Once we replaced the fuel pump & FPCU... it was like a beast unleashed. Also makes my 94 Q seem like a V6 any day.
Its a fact that Honda JDM engines are 10-20 HP stronger than USDM engines. Could it be the same for the Q45 engines? From experience I recommend it... only problem is that its a lot of work.
GseaQ wrote:In fact, the guy who maintains and repairs my cars (for the last 15 years) flat out refused to rebuild the heads on a colleagues Q after the timing chain guides lunched his engine. He said once you take apart an all aluminum engine and put it back together - no matter how right you do it - it's never the same.Glenn
Satan - Your going for performance and I agree with GseaQ.
