D_roc wrote:lol my fault not good at explaining things. but i think the fault is on the halogen bulb b/c a while ago i hooked it to the low beam wires and it worked ok then i hooked the wires to the hi beam and the whole thing began the hi beam indicator was on and was in low beam and when i put to hi beam the light didnt come up at allthen i hooked the factory bulbs and they work good so its eaither nissan has some wired kind of a lighting system or the small halogen is F#@%ed up but still it worked well under low beam so i'm clueless now
Modified by D_roc at 7:39 AM 8/17/2007
you seriously, seriously, need to start writing with more periods. you're next to completely unintelligible. to answer your question, it's rather easy. if two of your three female ports are in a bottom configuration, your negative will be on top, on your left will be the low beam, on the right will be the high beam. i picked up a hid conversion kit from
http://www.neverburnout.com and faced the same problem with a single beam configuration. if you think this is tricky, try doing it with a bixenon configuration.
take it easy
