blueballa »
https://forums.nicoclub.com/blueballa-u83809.html
Fri Jan 15, 2010 12:50 am
ok ok. im back my friends!! with a lot of info. please correct me if im wrong with any of this.. but im pretty sure im not. theses wires send signal to your ecu, coilpack, maf, etc.. etc.. etc. so this is one of the major parts of the harness. so if you checked everything out (used the search button).. then read on. if you havent, then dont. this should be your last resort. and if you post before researchin imma slap you. but dont be afraid to ask questions lol.
first off, you should have two sides, one side consisting on the sr harness and the other side that consists of the plug you chopped of from your stock harness. (if your wondering i used a redtop that replaced my sohc in my coupe)
ALSO!, ALL THESES WIRES ARE CONNECTED TO THE EXACT SAME ONE ON THE OTHER SIDE OF HARNESS. SOOO WHAT DOES THAT MEAN? that means, from the plug, you just match theses wires ive listed below with your sr20 harness and your set. there will be 4 wires you do not use at all. just leave them alone.
ok, from the larger connector (near the battery) you need to have the following wires connected:
red w/ grey dotblack w/ purple stripgreen w/ yelow stripyellow w/ green strip plus grey dotblack w/ white stripblue w/ green strip plus grey dot ( kinda hard to see the green strip so be carefull)black w/ yellow strip plus grey dot red w/ black strip plus grey dotorange/ grey dotblack w/ grey dot
ok this is the tricky part!! SO LISTEN UP!.
there are two thick wires left on the sr harness (thick black w/ purple strip and thick blue w/ red strip) and on the plug side there should only be a thick black w/ purple strip. what you do is combine the black w/ purple strip and blue w/ red strip from the sr harness and connect it to the single black with purple strip on the plug side.
there you go. heres some pictures.
red w/ grey dotblack w/ purple stripgreen w/ yelow stripyellow w/ green strip plus grey dotblack w/ white stripblue w/ green strip plus grey dot ( kinda hard to see the green strip so be carefull)black w/ yellow strip plus grey dot red w/ black strip plus grey dotorange/ grey dot & black w/ grey dotthick black w/ purple strip and thick blue w/ red strip
well i hope this helps everyone with there no spark or connection problems.
good luck and enjoy. oh btw, tell me how it does!!!
Modified by blueballa at 3:00 AM 1/15/2010
