OK, I've scoured Nico & The net, but not having any luck...Headlights
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
Headlight issue. Seems so many of these cars are having headlight issues (well, they are up there in age). Since my search hasn't turned up a definite answer yet, I'm starting a thread, hopefully when I resolve this, it may help someone else in this predicament.
Here we go.
Got this car, Someone had wired in HID's, and someone else partially yanked them out (no ballast boxes or bulbs left, just the relays and wires).
The main beam connectors had a harness/jumper plugged in for the HID's into the H4 3-prong connector, these were somehow wired (sketchily) to the foglights as well. I unplugged them, disconnected all of the extra wires and made sure what I could see was straight. Found some bulbs in the glovebox, put them in and plugged them up. Tried it out.
Result: No parking lights, right Front headlight not working, high beams won't turn on or flash. Signals work, hazards work, foglights work.
Testing with a multimeter, found that all 3 prongs of the RF connector had continuity between them :ohno:. After a quick internet search, I went and checked the rotary switch; one wire in the connector melted and the plastic fused into the switch. Had to pick and pry the connector to release it from the switch.
Got a replacement switch and connector, wired that in, plugged it up. Didn't hook up the right side light at this time, just in case the replacement switch would have burnt out as well.
Noticed that the high beam indicator came on once the lights were turned on, even when only the parking light should be engaged. No matter how I move the stalk. Unplugged the battery, went at it again with the multimeter. The red w/green stripe wire (Which I have found out is the RF high beam wire) has connectivity with ground. The other 2 wires now test fine. At this time, I didn't know this wire was the (right side) high beam wire. At the relay, this wire has the same issue. Went in the Cabin to see if I can trace this wire to something else, where it runs other than the rotary switch. Found it at the signal stalk.
Unplugged the stalk to see if the short was in that, no dice; testing the wire in the unplugged connector it has connectivity to ground as well... This has me thinking that the short cannot be inside the signal stalk itself, and the wire has to be shorted to ground somewhere, right? Is there any other component that I can check?
I've searched google, nico, sau, driftworks, zilvia, skylineowners...EVERY site where anything skyline or RB swapped has a headlight or wiring issue... Most people have solved the issue with the switch, bulb, or relay... :gotme
I haven't given up, I'll be back at it tomorrow morning (Today was a REALLY rainy day as well...) continuing to poke around with my multimeter. I just want to see if anyone can help me narrow down my search, give some insightful info or tell me about something I've missed/overlooked. :poke:
Oh yeah, last bit... THIS may have something to do with it, but I'm not entirely sure...
Image I'll get more detailed pics of this nest if anyone thinks this could be an issue.
M35Squirrel
Car: 1990 Nissan GT-R
2011 Infiniti M37
I shared your picture of burnt headlight plug at another Skyline forum because it seems to be a common issue.
This may not be the solution you are looking for or can only be used as a last resort, but there is an aftermarket harness kit for FairladyZ that basically sends 12v power source straight from battery to headlights with a inline relay that gets its signal from headlight switch. Hopefully this kit could bypass the 12v wire you are trying to solve.
Part #10-679
http://www.blackdragonauto.com/icatalog ... px?Page=65
PantherRacer
Hey, thanks.
It actually was the switch that caused the front light not to work (my smart self forgot to put the fuse back in when I was testing it :blush: )
Still working to sort out this brights staying on issue, I'll be taking apart the turn signal stalk to diagnose what I find in there. I'm still wondering if this red/green stripe wire is grounded out somewhere, as I've said before, even with the stalk unplugged, it's giving me connectivity with ground...
PantherRacer
Ok, (light) problem solved. The stalk contacts weren't burnt too bad, but cleaned them up anyways.
I'm still going to have to diagnose and tidy up all of those wires for the turbo timer, but I've foudn the reason the high beams wouldn't come on.
They were wired to come on with the foglight switch. I don't know how they have the high beam wire hooked up, but the indicator for high beams still comes on with the rotary switch, and the stalk does nothing to change this.
So all in all:
Rotary switch shorted and caused right hand side main beam not to function
Someone(s) poorly wired up and disconnected an HID setup: H3 high beams are wired into foglight circuit.
High beam indicator still comes on as soon as parking lights are engaged, still tracing wire.
All my lights come on now though, just the little annoyance of having my fogs and highs on the same circuit for now.
frracer
We can supply replacement connectors
frracer
look us up supertec racing on Facebook or Instagram
Return to “GTR Forum / Skyline Forum”
